Spark Plug Wire Confusion
Old Jul 5, 2007 | 01:19 PM
okdiscoguy's Avatar
Default RE: Spark Plug Wire Confusion
ORIGINAL: scubasteve
I'm going to tackle this project when my magnacor wires arrive. Thanks Mike for the advice. Does anyone have a step-by step procedure for removing the plenum?
Thanks
If you go to rover-renovations.com, they will send you a free Rave CD. It might take a while to get to you, so if you are in a hurry, you can get one on E-bay for a few bucks. It will have most of what you need.
Old May 12, 2008 | 12:01 PM
unstable's Avatar
Me and my wife just changed to the magnecor wires yesterday. I don't think my DII has secondary air but mine looks identical to the pictures you posted. We didn't have to remove the intake manifold. The job took roughly 3 hours to do but in hindsight I think it can be done in about an hour.
The biggest mistake that we made when we first approached the job was attempting to do one wire at a time. This is the usual approach for changing wires so you use the correct length wire in the appropriate place and don't get wires mixed up or plugged into the wrong terminal / cylinder. However; the problem with using this approach on the Disco II is that the bottom row of coil terminals are impossible to access when you have wires plugged into the top row of terminals.
Here's how I would recommend doing it.
-Recruit your wife, girlfriend or teenage son. If you do not have a wife, girlfriend or teenage son...borrow one.
-Begin by disconnecting each wire from the spark-plugs and write on the rubber boot the cylinder number. The reason you are doing this is because you are going to disconnect every wire from the coil pack.
-On the firewall running from left-to-right there is a bundle of something that is covered in ribbed plastic wire loom. It is held to the firewall with a couple of metal spring brackets. You will need to pull this bundle out of the brackets to give yourself a little extra room.
-Have assistant disconnect each wire from coil pack.
-Replace wires in the following order (2,3,4,7 - bottom row on coil pack.)
-Match new magnecor wires to old wires based on length and cylinder number
When it comes to the top row of wires on the coil pack, my wife had said that certain terminals were a little lower than others and she wanted to replace the low ones first. Your helper should be able to tell which terminals are difficult to access and the best way to install the wires to facilitate getting the job done.
I hope that this helps. Disco Mike gave me the following chart of the coil terminals
P--------D
8--5--6--1......Top Row
2--3--4--7......Bottom Row
I can't remember the cylinder layout otherwise I would post that also.
CPDieker
Jun 6, 2012 09:36 PM
primey
Oct 26, 2011 07:24 PM
sdsilvere38
Jun 14, 2010 08:35 PM
Disco2Fever
Apr 18, 2009 04:34 PM
kcirtap
Oct 10, 2007 06:43 PM
