Spark Plug wire length question....
Old Jan 8, 2011 | 03:09 PM
blast20's Avatar
Default Spark Plug wire length question....
01 D2 Quick question - I know this is a bit of a long shot, but I have an arching plug wire on #6 and I need to order just that one from Magnecor. Since they are a bit of a pain to get to, I'd rather order one and then remove/replace at the same time so that my truck is not sitting for days on end waiting for the replacement wire. I called Magnecor and they need to know the length of just the wire - not counting the rubber boot/end. Just the wire itself. Mine are Magnecor's but I figure other brands would be the same. Again, it the #6 cylinder (passenger side). Can anyone help? Thanks -
Old Jan 8, 2011 | 10:52 PM
disc oh no's Avatar
I think they just want a basic length of the bad wire so they can make you a new one. Are you asking if you can just measure one of the stock ones and give them that measurement, wait for the new wire and then replace? I think that would probably be fine. As far as it sitting... I don't know if I'd drive it with that wire arcing. If it's arcing, it probably isn't firing the plug too well.
Old Jan 9, 2011 | 10:36 AM
Just ask them to send the longest wire that comes in the Disco wire set and you'll be fine.
#6 has always been a common wire to fail, so a longer one will help prevent this.
Old Jan 9, 2011 | 06:34 PM
blast20's Avatar
Yes that's exactly what I want to do, but the wires run in back of the motor and I can't get an accurate measurement....I want to do the job all in one day and was just hoping someone knew the length of the wire so I don't have to take everything apart and let it sit. I've been driving with the arching wire for a couple months as it turns out.
CPDieker
Jun 6, 2012 09:36 PM
primey
Oct 26, 2011 07:24 PM
sdsilvere38
Jun 14, 2010 08:35 PM
werldcup
May 12, 2008 12:01 PM
kcirtap
Oct 10, 2007 06:43 PM
