Spark Plug wire removal from plug
Hello there,
I need help badly, I am trying to replace my spark plugs, but the spark plug wires are really very hard to pull out, I destroyed one boot already, the boot twists around the plug but my guess is the piece that grips around the plug tip does not want to give. I tried hose clamp pliers from harbor freight, bought several plug pliers from the internet, no luck. Any ideas on how to remove them without destroying it. Thanks
I have had good luck with a proper sized open end wrench, on different cars, its hard to describe, but take the open part, place it around the wire end, then use the wrench as a sort of pry bar to pull the wire up, on our E55, it is actually the best way to remove the 16 plug wires, I have used the same technique on a sticky wire on a plug on a chevy blazer.
Hello there,
I usually use something like and get it out faster. But your problem now is the other end of the wire when removing them.
