Spark Plug wire removal from plug
Old Jun 6, 2017 | 08:16 PM
eli93245's Avatar
4th Gear
Default Spark Plug wire removal from plug
Hello there,
I need help badly, I am trying to replace my spark plugs, but the spark plug wires are really very hard to pull out, I destroyed one boot already, the boot twists around the plug but my guess is the piece that grips around the plug tip does not want to give. I tried hose clamp pliers from harbor freight, bought several plug pliers from the internet, no luck. Any ideas on how to remove them without destroying it. Thanks
Old Jun 6, 2017 | 08:35 PM
Daedrix's Avatar
Banned
Worse case scenario use a box cutter to get enough material to fit a socket over the plug to remove it and change the wires.
Old Jun 6, 2017 | 08:39 PM
emncfi's Avatar
I have had good luck with a proper sized open end wrench, on different cars, its hard to describe, but take the open part, place it around the wire end, then use the wrench as a sort of pry bar to pull the wire up, on our E55, it is actually the best way to remove the 16 plug wires, I have used the same technique on a sticky wire on a plug on a chevy blazer.
Old Jun 7, 2017 | 11:28 AM
Luckyjayb's Avatar
When u put new plug wires on, get the boot Kevlar/ceramic covers on them. It helps the boot last longer by keeping the heat directly off them.
Old Jun 7, 2017 | 01:41 PM
LR03NJ's Avatar
Originally Posted by eli93245
Hello there,
I usually use something like
this this
and get it out faster. But your problem now is the other end of the wire when removing them.
Amazon Amazon
CPDieker
Jun 6, 2012 09:36 PM
primey
Oct 26, 2011 07:24 PM
sdsilvere38
Jun 14, 2010 08:35 PM
werldcup
May 12, 2008 12:01 PM
kcirtap
Oct 10, 2007 06:43 PM
