Spark Plug and Wires Question
Old Nov 28, 2008 | 03:58 PM
Default RE: Spark Plug and Wires Question
ORIGINAL: pilsner
craineface,
can you repost the directions or a link here for me please? changing out of wires and plugs is on the agenda for next weekend.
thanks
pilsenr
Her's your link,
https://landroverforums.com/m_41479/tm.htm
Old Nov 30, 2008 | 09:30 PM
pilsner's Avatar
thanks! good work! as always!
jaynes
Old Jan 1, 2009 | 03:29 PM
BullRover's Avatar
4th Gear
I took the advice and now have the crankshaft (CKP) sensor.
I was looking at the procedure and it is saying that I need to:
9. Reset adaptions using TestBook.
How do you reset the adaptions? I assume TestBook is a computer that can adjust the ECU right? Can most workshops do this? I would like to stay away from the dealer. Can I reset the adaptions myself or at a autozone?
Also it says to:
4.
Release fixings and remove underbelly panel.
whatexactly is the underbelly panel. I am having a hard time getting my hands up to the sensor connector but have not raised the front end yet. tha may give me some room I hope.
Thanks for the help and advice from everyone.
Happy New Year.
[IMG]local://upfiles/12307/A87C127A83444A6EA0F9B804C5E7619C.jpg[/IMG]
Old Jan 1, 2009 | 04:47 PM
Only a Rover dealer has the TestBook, it is a $3000 computer for Land Rovers.
Just replace the crank sensor and you will be fine.
The underbelly pan is a cover over the bottom of the engine, yours might be missing.
Old Jan 1, 2009 | 11:06 PM
BullRover's Avatar
4th Gear
Thanks.
I know what you are talking about the underbelly cover now. Mine is still on but if I'm not mistaken itis forward of where the cranksensor is. Disco Mike said some of the other owners remove theirs with no problems and that it may even allow for better cooling in another post.
As far as removing and replacing the sensor, I am having a heck of a time getting my hand up to the sensor to disconnect the connector and just wanted to know if there are any tricks to getting at it a little easier.
Again, I appreciate the help.
mikedemet
Jan 29, 2021 02:02 PM
primey
Oct 26, 2011 07:24 PM
maing74
Aug 26, 2011 05:05 PM
mikedemet
Mar 7, 2006 12:07 AM
kfordric
May 30, 2005 11:29 PM
