Spark plugs holes stripped
Old Feb 20, 2011 | 04:19 PM
aarons02's Avatar
Default Spark plugs holes stripped
I changed my spark plugs yesterday. First time I have done this to my 02 Disco, it has the 4.0.
All of the plugs felt seized as i took them out.
I had to wrench them the entire way out.
Either threads were already bad, or I ruined 2 of them removing plugs.I now have 2 that are puffing air out of head.It still seems to run okay, which seems strange?
I tapped holes very slow and careful, but soft metal is shot. I need some info on what to do.
Is there a repair kit for this? Or will I have to remove heads to repair?
And is there a temporary fix other than JB weld that wont ruin heads?
And one more question, Can i use the rig like this, or will this cause more damage?
Appreciate any help,
Thanks
Old Feb 20, 2011 | 04:25 PM
jrm123180's Avatar
I had that issue on my 03...went to Pep Boys and bought a kit to repair this...worked well, no issues since. Did it with the head still on.
Old Feb 20, 2011 | 04:44 PM
humroot's Avatar
Any auto store has a tool that will re-thread the holes. There is also something called a heli-coil that is used to fix stripped spark plug holes. I would check with a mechanic first before I started messing with them. I had one stripped and got it kind of fixed with the tool from the auto parts store. I finally got it permanently fixed when I did the head gaskets. Took the heads to a machine shop. Personally, if they are blowing air I wouldn't drive the truck too much.
Old Feb 20, 2011 | 08:21 PM
photocrimes's Avatar
I had a buddy who had a buggered up plug hole. The plug was holding on by a thread. He drove it for a while thinking as long as it was snugged down it was fine. One day cruising down the beltway he blew a plug through his hood. Ripped the boot on the plug wire clean off.
I don't think I'd run it like that.
Old Feb 21, 2011 | 06:25 PM
aarons02's Avatar
I have tried tapping, didnt help. So I will try Heli-coil. Can this be done with the head installed? Or do i have to pull heads off? Which would I would rather not.
Thanks
Old Nov 29, 2018 | 01:57 PM
Betty4banger's Avatar
You can install while the heads are still on you just have to take your time and make sure you blow out any metal shavings form the cylinder before your done. I would turn one full turn and them back it out. Repeat that until your all the way in.
Old Feb 16, 2020 | 03:23 PM
Carlos Man's Avatar
Any updates? How did you over come rethreading at the correct angle?
Niver39
Nov 7, 2024 11:14 AM
lrjon
Feb 15, 2020 04:14 PM
walkingzach
Jun 17, 2014 10:34 AM
Torancis_LR
Jul 10, 2009 11:27 PM
adwarren78
Mar 24, 2009 07:52 PM
