Tricks for Installing Spark Plugs
Old Jun 16, 2014 | 08:16 PM
walkingzach's Avatar
Default Tricks for Installing Spark Plugs
does any one have any tricks or advice for installing spark plugs?
i could not for the life of me get the threads started...
i was trying to be very careful not to cross thread the plugs, but once it felt like i got the threads engaged i couldnt get an angle to get the spark plug finger tight.
Old Jun 16, 2014 | 08:24 PM
blamo's Avatar
I use a spark plug socket & extension and use only your finger .
Old Jun 16, 2014 | 09:38 PM
ralphobell's Avatar
Clean your threads first with a spark plug thread chaser.
Great Neck/Metric spark plug hole thread chaser (25124) | Thread Repair | AutoZone.com
Old Jun 16, 2014 | 09:40 PM
Colorado David's Avatar
Only change plugs with an absolutely dead cold engine.
Old Jun 16, 2014 | 09:45 PM
abran's Avatar
My buddy showed me a trick. He uses a length or small diameter rubber hose that fits on the nipple. Then he uses the hose attached to the spark plug to twist it into the threads. The delicate nature of the hose makes it impossible to cross thread.
Old Jun 17, 2014 | 07:22 AM
drowssap's Avatar
"He uses a length or small diameter rubber hose that fits on the nipple. Then he uses the hose attached to the spark plug to twist it into the threads." x2
or and old boot off a wire
Old Jun 17, 2014 | 10:34 AM
OffroadFrance's Avatar
x3 or a rubber hose that fits tightly over the ceramic insulator if it fits down the plug tube in the head, otherwise as above.
You can also find plug spanners with a grommet insert that fits over the ceramic to stopp the spark plug dropping down too early. I have one came with my LR toolkit in the 200 D2 V8.
OffroadFrance
Off Topic
Jan 14, 2015 04:56 PM
chakadog
Feb 11, 2008 02:36 PM
shawn
Dec 21, 2007 11:53 AM
shawn
Oct 4, 2007 09:10 PM
alpinab7
Nov 27, 2006 07:34 PM
