Specific Amigos Scenario - need help.
Old Dec 9, 2023 | 07:41 PM
Nomadsoul's Avatar
5th Gear
Default Key On Self Test Fail 3 Amigos - need help.
Bought a 99 with three amigos. Got it scanned and found that it was a wheel speed sensor. I cleaned and re-seated the sensor and the amigos went away and everything worked. Exciting! This lasted about 3 key cycles and then I started getting the lights back, but this time in a different way. Here's what happens:
When I turn the key to position 2, all the cluster lights illuminate, when they shut off, the ABS light stays on, the HDC and ETC lights turn off briefly, while the ABS pump cycles, pulsing the pedal (self test) which must fail because the HDC and ETC lights then turn back on.
I'm thinking that the pulse test failing must be indicative of something and I don't personally have a scanner, so it costs money everytime I want a scan.
And a side question, I have a suspicion my brakes aren't bled properly. Could that cause the key on test to fail? Is doing all 4 corners by jumping the ABS relay going to give me a proper bleed like a nanocom would ?
Thanks for the help!
Old Dec 9, 2023 | 07:52 PM
Extinct's Avatar
Suggest you get the icarsoft i930 for LR from Amazon, it will scan all the brake and trans codes. iCarsoft i930 Pro Multi System Diagnostic OBD2 Scanner for Landrover/Jaguar ABS SRS https://a.co/d/dnN0e5j
Old Dec 10, 2023 | 11:19 AM
mollusc's Avatar
I don't recall that my ABS pump cycles when I turn the key on.
Old Dec 10, 2023 | 12:08 PM
mln01's Avatar
First, welcome to the forum, Nomadsoul. I see starting this thread was your first post here.
It's well known here that wheel speed sensor (WSS) faults are very, very often caused by problems with the electrical connectors between the WSS and the self-leveling and anti-lock braking system (SLABS) computer located behind the glovebox.
You don't say which WSS was indicated when you had the codes read, but I recommend unplugging, cleaning, and reconnecting all the connectors leading from the WSS to the SLABS, including the connector at the SLABS itself. I use QD Electronic Cleaner.
https://www.crcindustries.com/qd-174...aner-11-wt-oz/
If you don't have the Discovery II Workshop Manual you can download a free PDF copy from the link in my signature below. If you don't have the Electrical Library and Electrical Circuits PDFs you can google those titles and download them free also.
Old Dec 11, 2023 | 09:44 AM
Nomadsoul's Avatar
5th Gear
Is this the best scanner for the money then? I dont care about key programming cause i know that's $$$. But, I need to be able to see live wheel sensor output, and power brake bleed would be nice.
Old Dec 11, 2023 | 09:47 AM
Nomadsoul's Avatar
5th Gear
It was passenger front. I checked the resistance on the shuttle switches but did option B anyway.
I'd reaIly love to know what exactly is being checked when the truck does this ABS pump cycle when turning the key on. I imagine some people don't notice it happening because a specific condition hasn't been met in my case that's making it do the test.
Old Dec 11, 2023 | 10:32 AM
gecko951's Avatar
Yes, the icarsoft i930 is the best value for $$$ LR specific scanner!
Old Dec 11, 2023 | 03:35 PM
Nomadsoul's Avatar
5th Gear
Can you confirm live wheel sensor output?
Old Dec 11, 2023 | 06:04 PM
Extinct's Avatar
It will do both of those. Also reads transmission codes and status on newer LR's anJags.
Richard Gallant
Oct 4, 2021 12:55 AM
slink182
Sep 9, 2016 09:47 AM
JLandy
Mar 15, 2012 04:17 PM
Disco04
Dec 29, 2011 03:32 PM
Chevyman7488
May 5, 2010 07:36 PM
