Speedo questions
Old Jul 3, 2018 | 10:53 AM
Fastercat's Avatar
Default Speedo questions
As I live in Canada and my truck is from Georgia I tried swapping out a metric speedo into the gauge cluster. I was told on here that I couldn’t swap the whole cluster as they tie into the bcu and won’t work. I originally tried to pull the pointer off the displays and swap the papers but they don’t come off without breaking that I can see. So I ended up swapping the speedometer mechanisms. Now it starts at 80km per hour and counts down as I accelerate. Lol. Anyone play with these guage clusters before or know how I can get my bcu to work with a metric gauge cluster?
Old Jul 3, 2018 | 11:23 AM
Sixpack577's Avatar
You can contact wwwblueguages.com
They should be able to help.
Old Jul 3, 2018 | 11:26 AM
Sixpack577's Avatar
You can try
www.blueguages.com
They can probably help you.
Old Jul 3, 2018 | 12:27 PM
Best4x4's Avatar
I know holding down the trip button switches between MPH/KPH on the odometer.
Old Jul 3, 2018 | 07:41 PM
jamestfl's Avatar
The only answer to speedo questions is: only in Europe, and even then it's best to have the body for it. Good luck.
Old Jul 5, 2018 | 04:41 AM
JUKE179r's Avatar
Did you insert all the screws onto the gauges when you tested it?
I remember mine was bit wonky when I only added a few screws to test out my gauges after I added LEDs. I then added all the screws and tightened them all down for it to work correctly.
Old Jul 5, 2018 | 06:54 AM
Fastercat's Avatar
I’m going to pull it back apart tonight and try to hold it at zero when I apply power, I’ll check the screws, orientation of the drum, whatever else I can think of. Any ideas feel free to chime in
Fastercat
Dec 3, 2017 09:01 PM
KingKoopa
Nov 11, 2017 09:55 PM
Sabas79
Range Rover Evoque
Mar 1, 2016 11:15 AM
Best4x4
Oct 12, 2015 10:27 PM
sdyver
Jul 7, 2012 11:15 PM
