Spot the Oil Leak
That's the cam sensor...not oil pressure sender.
Replace crank seal, you're that far. Just check your harmonic balancer over good (surface where seal rides).
I believe, there are o-rings on those plugs (from reading topics here, no personal knowledge). After looking at that plug again, l'm not so sure it's leaking anything out of there...looks like whatever is making oil stain is from above.
robert.juric (07-25-2021)
Also, you can order an o-ring for the camshaft sensor (https://www.roverparts.com/engine/ga...eals/ERR4815G/) P/N ERR4815G.
The PCV mod won't stop existing leaks, but after replacing bad seals, will prevent them from happening as often or as frequently as they've been.
