Spot the Oil Leak
Old Jul 24, 2021 | 03:44 PM
robert.juric's Avatar
Default Spot the Oil Leak
Do you think it’s the main seal or that oil pressure switch leaking? Also any clue about how to clean up the cap on the side?
Old Jul 24, 2021 | 04:19 PM
The Deputy's Avatar
That's the cam sensor...not oil pressure sender.
Replace crank seal, you're that far. Just check your harmonic balancer over good (surface where seal rides).
I believe, there are o-rings on those plugs (from reading topics here, no personal knowledge). After looking at that plug again, l'm not so sure it's leaking anything out of there...looks like whatever is making oil stain is from above.
Old Jul 24, 2021 | 05:56 PM
Extinct's Avatar
All of those leaks are because you have not done the PCV mod, do that and everything will stop leaking. Tighten the VC bolts too.
Old Jul 25, 2021 | 01:46 PM
Yea it’s on order. I’ve got some time now that I snapped a bolt torquing the coolant pump.
Would the PCV mod fix the leaks or do seals need to be replaced?
I did pull the camshaft sensor and put some RTV around the edge.
Old Jul 25, 2021 | 03:15 PM
Brandon318's Avatar
The PCV mod solves an issue that sort of makes leaks much worse. The stock PCV clogs up and creates a higher-than-normal crankcase pressure, which needs to escape one way or another, and if it's not through a properly working PCV, it's coming out the weakest seals first.
Also, you can order an o-ring for the camshaft sensor (https://www.roverparts.com/engine/ga...eals/ERR4815G/) P/N ERR4815G.
The PCV mod won't stop existing leaks, but after replacing bad seals, will prevent them from happening as often or as frequently as they've been.
swissarmychainsaw
Dec 11, 2020 09:57 AM
sayeedA
Feb 19, 2017 03:04 PM
dsmeddy
Jun 25, 2016 02:34 PM
djblackrain
Sep 13, 2012 10:12 PM
kfox77
Apr 25, 2009 01:29 PM
