Spring compressor needed for TF 2" lift?
IMHO the bottle jack is quicker to get your axle to drop a little more to insert the spring and also safer. The Spring Compressor is time consuming, scratches the paint on your coils (they tend to slide around at first until it's tight on the spring), and you MUST align them properly across from each other as to not damage the spring during install, but with the spring perch/frame in the way that isn't always as easy as it sounds to do.
I've done at least 10 D1/D2 lifts and the bottle jack is without a doubt the winner vs the spring compressor tools.
Honestly with an OEM bottle jack lifting your D2, you should be able to install some jack stands, and with the tires & shocks off you should be able to get the axle to fully drop (if equipped with larger tires a block under the bottle jack is handy to compensate for the larger tires). Then stick the bottle jack in one side between the axle (on the bump stop flat spot for example) and then on the frame and pump it until you can remove the coil.
I do take the time to remove the ABS/Brake line bracket on both rear sides to prevent any damage to them (I think it's a single 10mm on each side).
As for tires, for now I am with stock 255/55 R18's so there is no adding a bigger tire during the lift. Glad also to hear about the bottle jack. I really did not think that thing would extend enough to even get my tires off the ground in the event of a flat. LOL.
I feel a lot better about the process. Just waiting for summer to roll around. I teach, so I have time off to get myself into more projects than I could ever want (and can afford) :-)
Bottle Jack makes it quick and painless with just a few pumps vs cranking down a spring then trying to install it only to find out the coil spring compressor tools are in the way of the frame or coil spring mount.......
On the front you let let the axle drop as far as it'll go, then stick the bottle jack between the frame/axle and pump it just a few times until the new spring slides into place (I can normally remove the OEM springs once the axle is at full drop). For the rear I do unclip the ABS lines and disconnect the one brake line/frame mount so I don't stress the brake line/ABS line. Then I use the bottle jack just like with the front axle and place it between the frame and axle.
LoL well thanks Juke! I remember old Disco Mike. He had his good and his bad days.
I'm just here to help, and try to offer tips/tricks on how to keep our D2's going for many many many years!!
I was talking to a friend and he was going on and on about his new 45K Toyota 4Runner. Sure it has a more advanced stereo, more advanced HVAC control center, and it's got that great new car smell, but I walked away thinking I love everything about my D2's and my LR3. There is just no way I'd go out and buy a 45K 4x4 SUV when I could just repair my LR's when they need it vs that.
I love trying new things or doing research on something and coming up with a more modern/improved setup/design vs what our LR's rolled out of the factory with.
jamieb
Apr 2, 2016 10:33 AM
TheWhiteRover
Sep 12, 2014 08:57 PM
southfloridadiscoII
Jun 18, 2009 08:48 AM
