Springs swap
I've lifted two this way. Check out the link in my signature. Some of the info is outdated, I need to update the post, but rear springs in the front will net you 3.5" lift. I cut/weld the shock towers lower in the front. The rear I make a spacer and I weld in extension tabs on the rear shock mounts.
Sounds as though they are interchangeable- however different footprint..
I have a newer set of HD rear & would like to maybe try them front and go heavier duty in rear to see for myself how it rides & compression stance.
I’m not interested in doing a budget “cut” /welding here. i had seen your execution Alex_M - Just the thing for some..
SundayFunday (04-16-2020)
