squeaking brakes
Old Mar 8, 2009 | 09:10 PM
mwsharb's Avatar
Default squeaking brakes
My brakes are squeaking, rear ones I think. I have a 2000 Discovery II. The squeaking started reciently. Rear brakes replaced 6000mi ago by a dealer. What can I do to stop the squeak before it causes problems? As I understand it this can cause the three amigos to come on.
Old Mar 8, 2009 | 10:03 PM
tornado_735's Avatar
Just covering bases....you sure it's not the front driveshaft doing the squeaking?
Old Mar 9, 2009 | 11:18 AM
Removing the pads, sanding them and installing sound deadening spray may do the job.
Old Mar 9, 2009 | 11:42 AM
sloppyjoe's Avatar
i installed new pads a couple hundred miles ago.
rears turned into banshees,,,,
so saturday i pulled the rear pads out and sanded the discs down and reinstalled the pads. so far so good.
Old Mar 9, 2009 | 12:31 PM
mwsharb's Avatar
I'm sure it's not the driveshaft, rear pads squeaking. Will take off and spray. They are RR pads.
Old Mar 9, 2009 | 02:22 PM
Rover pads can be noisy also, may need to do as I already mentioned and scuff up the rotors a little, rinsing them off with brake cleaner after wards.
mstrachan1986
Sep 16, 2014 12:10 PM
Quinn519
Mar 27, 2014 05:40 PM
KernowDiscovery
Dec 18, 2013 07:57 PM
Aj6543
Nov 7, 2009 05:35 PM
wolfecon58
Jun 8, 2009 11:41 AM
