Squeaking/squealing - what is it?
Old Dec 16, 2025 | 09:23 AM
  #21
WeatheredSoul's Avatar
I ordered a new drive shaft from Tom Woods. Probably should have put it on and tested to see if the noise was fixed before draining the diff but I wasn't thinking and was really curious to see how the drain plug looked. Quite a bit of metal if you ask me.
Im going to change the fluid put the new drive shaft on and see what happens.
Old Dec 16, 2025 | 09:29 AM
  #22
Brandon318's Avatar
Aye, I’d set your expectations at needing to replace the diff. It’s really not a difficult job at all.
Old Dec 16, 2025 | 09:47 AM
  #23
Where did you end up buying your front 3rd member from?
Old Dec 16, 2025 | 11:06 AM
  #24
Brandon318's Avatar
Sorry, what do you mean?
Old Dec 16, 2025 | 11:20 AM
  #25
didn’t you replace your front diff? I’m curious if you remember where you got it from?
Old Dec 16, 2025 | 11:50 AM
  #26
gecko951's Avatar
Check the local Pick-n-Pull, car-part.com, Ebay and Will Tillery Land Rover New and Used Parts and Accessories ? RoverGuy Land Rover Parts and Accessories
Old Dec 16, 2025 | 12:34 PM
  #27
Brandon318's Avatar
Oh gotcha. Sorry I didn't understand what 'front 3rd member' meant. I just got it on eBay from ohiovalleyrovers.
Old Dec 16, 2025 | 12:41 PM
  #28
Has anyone used Roverland parts? They're used but they back them with 6 month warranties which is nice.
Old Dec 17, 2025 | 11:03 AM
  #29
ahab's Avatar
Is the centering ball of the cardon joint greaseable? I had a similar noise that started as a squeak and evolved into minor shudder at takeoff accompanied by a sphincter-tightening shriek at speed, 12 hours from home. I removed the front axle and the sound went away. Further inspection revealed that the centering ball was as dry as a chip. It was not greaseable but I was able to lube it with spray lithium grease to the point that the noise went away. I drove on it until I got a custom front driveshaft in a parts truck that was fully greaseable and now I keep it as a backup.
File Type: mov
Old Dec 17, 2025 | 11:10 AM
  #30
Got my fingers crossed this is it. Tom Woods fully greaseable front driveshaft shipped today so I'll install it when it comes and report back.
