Squeaky noise when Accelerating
Old 01-18-2010 | 10:49 PM
thomas22's Avatar
Default Squeaky noise when Accelerating
Whenever I'm at a complete stop and start to accelerate i hear a squeaking noise coming from underneath likes somethings dryed out. It never makes the sound when I'm in neutral or park giving it gas only when i accelerate driving there is also a tiny bit of vibration. I thought it might be the brakes so i change them all out also changed the oil and the transmission still doing it. Any Help?
Old 01-19-2010 | 12:05 AM
thomas22's Avatar
Here is a short video just the squeaking http://s668.photobucket.com/albums/v...1111111001.flv
Old 01-19-2010 | 06:24 AM
discoklein's Avatar
Thomas22, I am in South Bend too, have you checked the driveshafts for play or have you ever greased the u-joints that are greasable...?
Old 01-19-2010 | 01:59 PM
thomas22's Avatar
Yes there is some play in the driveshaft when i twist back and forth and i never had them greased i will do that see if it helps i think it might be bad u joints
Old 01-19-2010 | 02:02 PM
okdiscoguy's Avatar
re-build/replace your front driveshaft immediately. That is a bad u-joint. if it fails, your front shaft will slap the tranny out of the truck.
Linebacker
05-01-2019 01:00 PM
thomas22
01-25-2018 07:27 AM
khunba
LR4
04-03-2014 09:10 PM
Northwind
06-25-2012 03:25 PM
Giverny
03-27-2010 03:13 PM
Quick Reply: Squeaky noise when Accelerating
