SRC jeep bumpers on and DII
Old Feb 28, 2015 | 11:19 PM
  #71
If I was going to go with a jeep bumper to rework this would be the one for me.
07 15 Jeep Wrangler JK Rock Crawler Front Bumper 2X D Ring Winch Plate Ready | eBay
Old Mar 1, 2015 | 08:07 AM
  #72
Alex_M's Avatar
That looks exactly like a Disco bumper! I think I found the bumper I'm buying.
Old Mar 1, 2015 | 09:22 AM
  #73
Just remember the extensions going back to the wheel well openings were added to the bumper.
Old Mar 1, 2015 | 07:54 PM
  #74
swak6287's Avatar
Seller sold out of this one. Mssg him to see when he will get more in
Old Mar 1, 2015 | 07:55 PM
  #75
swak6287's Avatar
Armyrover, is this your setup? I would like to see the bumper brackets. I love the setup where it sits high and the winch is high up
Old Mar 1, 2015 | 08:16 PM
  #76
No it's not mine, my Discovery is stock. My Defender 110 on the other hand
Old Mar 1, 2015 | 09:18 PM
  #77
TOM R's Avatar
I also built my bumper, I have probly maxed my 12k winch, my mounts boxed the frame rails all the way back to the cross member then used grade 8 hardware, only grade 8 the bolts will probly rip the frame before breaking, 150,000 psi shear per bolt do the math
I went all the way back with the mounts so the frame takes the the verticle static weight of the bumper and winch, the bolts do noting but keep the bumper from sliding off unless I am winching, oh and my mounts are 1/4" steel
If you think its overkill it might just be enough, i look at it this way, winch should be at least double the rigs weight, winch line and all recovery stuff should be double the winch, weld that are going to be stressed by that winch should be high strength, my brother in law is a union iron worker he stick welded my winch mount with high strength rod ( don't recall the rod #and psi per inch it was high), rest of my bumper I migged, it is strong probly way stronger then a lot I have seen for sale
Just my .02
Old Mar 1, 2015 | 09:19 PM
  #78
TOM R's Avatar
I really want to see how the rear bumper mounted, or how a d2 rear bumper mounts in general
Old Mar 2, 2015 | 09:13 AM
  #79
drowssap's Avatar
swak6287
that is one of the nicest fitting front bumper i have seen, look like the TF only $300 cheaper, its not a bolt on, but $300 buys a lot a fab work.
maybe a rear bump.
Old Mar 2, 2015 | 09:51 AM
  #80
Looking at the pictures of how the mounts are set up to be honest I think the fab work would be pretty quick and easy to do.
Even adding the bit going back along the fenders would be pretty straight forward. It is tempting.
