SRS Air Bag Code
Old Nov 11, 2021 | 04:53 PM
zacharyz28's Avatar
Default SRS Air Bag Code
What do 0x16 and 0x20 SRS codes (below) mean? Can't find a definition anywhere.
Old Nov 12, 2021 | 06:56 AM
mollusc's Avatar
Those won't be true LR codes. You need to find a better code reader that will work properly with the Land Rover systems.
Old Nov 12, 2021 | 10:43 AM
zacharyz28's Avatar
I believe these are in hexadecimal and would translate to a regular decimal number. But I can't find a list of LR SRS codes anywhere. The Rave doesn't have one.
Old Nov 20, 2021 | 08:09 PM
zacharyz28's Avatar
Apparently the code numbers are state secrets?
Old Nov 21, 2021 | 11:44 AM
Harvlr's Avatar
You really need a code reader that will read Land Rover codes. Nanocom is really good but there are cheaper ones that will work also. Most likely issue is going to be an electrical connector that needs to be cleaned, but a proper reader will give you better direction.
Old Nov 22, 2021 | 12:25 PM
jastutte's Avatar
like Harvlr stated, you could probably just clean all the connectors, clear the codes and be good to go.
sometimes all it takes is unplugging them and then plugging them back in. i always spray electrical cleaner on both the male and female plugs, let them dry and then plug them back in.
Friday Night Disco
Oct 4, 2021 05:55 AM
_ExpeditionMan
Feb 26, 2019 01:26 PM
sorusty
Feb 20, 2014 08:15 AM
akamoore
Jan 16, 2010 08:12 AM
hanivw
Jan 25, 2008 12:50 PM
