SRS light on after seat swap
Old May 19, 2009 | 04:13 PM
RoveringAgain's Avatar
Default SRS light on after seat swap
In my last post, I noted that I had some seat swtich wierdness, but in addition, I now discover that the SRS light is on. I had the system scanned and was told that this is an non-reversable fault code, and that it's present in both seats.
So: any ideas??
The donor vehicle was a '99 SE which had what looked like a minor impact (front left corner crunched, but not badly, although the air bags did deploy), the seats are now in an '02 SD, if that is of any help.
Thanks a ton!
Stan
Old May 19, 2009 | 05:47 PM
okdiscoguy's Avatar
did you change out the seat belts when you swapped seats?
Old May 19, 2009 | 06:35 PM
Yeah your problem is in the seat belt latches/anchors/wireharness.
Old May 19, 2009 | 06:47 PM
Didn't occur to me to do that... Thought the ones on the seats would be fine.
Old May 20, 2009 | 04:53 PM
Ok, final word on this. I dug through the RAVE, the issue is simple. The seatbelt pre-tensioner is a pyrotechnic device deployed at the same time as the air bags. It's a one-trip device, and once it's blown, you have to replace it.
The SRS DCU detects that it's blown, and since that's a fault in the SRS system, sends signal to light the light.
So, as noted above, the fix is to swap that piece from the original seats. Or pay $250 a side to put in new pieces from the dealer. Not.
Thanks everyone.
Stan
Old May 20, 2009 | 07:40 PM
I didnt think about the pretensioners going off and setting the light.
Glad you got it figured out.
Do the swap and you should be good.
DiscoJonny
Apr 28, 2012 07:21 PM
wheelgarage
Jun 19, 2011 08:23 PM
cplthomas
Mar 29, 2009 09:49 AM
Willie 00D2
Oct 27, 2008 12:28 AM
mfryburg
Oct 19, 2008 10:38 AM
