SRS lite still on
Old Sep 4, 2011 | 11:40 AM
ajmille's Avatar
Default SRS lite still on
Ok, so I cleaned the the seat belts with electric cleaner as well as the conections , new battery, and alternater. Under normal driving conditions the SRS lite dosnt turn on, but soon as I step on the gas hard the lite turns on, any thoughts would be welcomed!
Old Sep 4, 2011 | 02:36 PM
discowhite1's Avatar
fuses
Old Sep 4, 2011 | 03:52 PM
Disco2001's Avatar
Underneath the drivers seat, at the rear passengers feet, is a velcro pouch type cover; open it and you will see a connector; try to open up, give it a blow out and reconnect; it solved my SRS light being on, but that was a continuous thing; not sure if it helps on the giving gas situation
Old Sep 4, 2011 | 04:18 PM
ajmille's Avatar
thank you I will try this
Old Sep 5, 2011 | 11:07 AM
ajmille's Avatar
my pride is up, I have tryed everthing that I could do, still the SRS lite is on, know I must go to a mechanic, witch I havnt been to in over four years. THE LAND ROVER HAS BEATEN ME!
Old Sep 5, 2011 | 11:11 AM
DaveBFoto's Avatar
Don't give up! You could still rent/borrow a Hawkeye to read the codes!
Old Sep 5, 2011 | 12:09 PM
Rovin4life's Avatar
actually unclip the tie straps that go to the seat belt pretensioners and give them some slack and see if it still comes on. if it doesn't then give them some room to move. Fixed quite a few that way on newer and older cars. to many tie straps too tight over time can affect the resistance.
Old Sep 6, 2011 | 08:39 AM
If you still can't fix it, go get those SRS codes read and get back to us with what you find.
ajmille
Aug 26, 2011 11:55 PM
TOM R
Apr 1, 2009 06:16 PM
Deb99DiscoII
Nov 1, 2007 08:21 PM
Kraftyz51
Oct 21, 2007 03:30 AM
jboy
Oct 29, 2006 04:13 PM
