SRS warning light
Old Sep 6, 2012 | 06:18 PM
ekahi_1's Avatar
Default SRS warning light
havent drove the rover for about a month but today when i was about to leave i noticed the SRS warning light was on??? but after work on my way home it was gone...then about 3 hours wile out driving it was back on...
what would cause the light to come on...
Old Sep 6, 2012 | 06:31 PM
Start with low voltage, go have your charging system tested, must be between 13.6 and 14.4 volts. If that is OK, then check and clean connections at the front seats.
Old Sep 6, 2012 | 06:54 PM
bballjames's Avatar
Probably seat belt pretensioners or rotary coupler. If you move the front seats you can loose a connection under there that will cause it to come on and off too. Mines been on for about two months. My rover mechanic told me it was probably the rotary coupler or something, but not to worry about it. I haven't...
Old Sep 6, 2012 | 08:53 PM
ekahi_1's Avatar
ya i just move the front seats foward the other day so i could put fold the back seats to haul stuff. ill go look under the driver seat tonight. after doing a google search i read a couple other post with the same problem. And ill also check the volage.
thanks for the help!!!
cipher982
Nov 9, 2019 11:22 AM
mvjimenez
Jun 12, 2010 10:25 AM
alanroberts50
Dec 13, 2007 06:18 PM
Rovercountry
Dec 25, 2005 09:42 AM
anonimaus
Mar 14, 2005 12:39 AM
