stalling disco2
Old Dec 10, 2012 | 08:31 PM
micahneil's Avatar
5th Gear
Default stalling disco2
I have a 2000 disco2. When I pull up to a stop sometimes the rpms drop off real low and sometimes it will die. It seems to be worse in low range. If I put it in neutral as soon as I stop it is fine. It does not do it all the time but it does it enough to be bothersome. Run 93 octane. Have recently changed plugs and wires. Getting ready to change trans fluid and filter. Any other suggestions would be greatly appreciated.
Thanks Micah
Old Dec 10, 2012 | 08:50 PM
Idle air control valve, could clean with carb cleaner. Also check for vac leaks.
Old Dec 11, 2012 | 09:14 AM
Did this happen after you did the tune up, what brand of plugs and wires did you use? Also, clean the t/body with carb cleaner.
Old Dec 12, 2012 | 07:24 AM
micahneil's Avatar
5th Gear
Mike,
It was doing it before the wire and plug change. Not any better or worse. When I first stop it is okay for a few seconds then it will bog down sometimes and then it is like the transmission goes into neutral even though it is in drive. In 4 low when I stop and it bogs down it will die most of the time. It will start right back up with no problem. It idles fine in park and nuetral. Starts fine and the transmission does not seem to be slipping.
May not be making any since to you but I appreciate the help in advance. Love my Land Rover.
Micah
greenoval
May 11, 2006 11:45 AM
MikeRover
Jun 25, 2005 04:34 PM
slamwhit
Jun 17, 2005 05:11 PM
trailhead4x4
May 25, 2005 08:48 PM
Bene
May 1, 2005 04:21 AM
