Start up after front engine cover and oil pan removal
Old Nov 17, 2009 | 09:49 AM
lipadj46's Avatar
Default Start up after front engine cover and oil pan removal
So I have everything back together (getting the front cover on over the key in the crankshaft is a PIA). I have never started a engine after a front cover job. I assume I have to prime the oil pump but I don't have a little oil can/pump. Can I fill the filter with oil and pull the fuel pump fuse and ignition coil fuse and turn it over for 10 seconds to get the oil pump primed. Or do I need to prime the pump manually? I did not replace the pump just did the gaskets.
Old Nov 17, 2009 | 10:48 AM
Just fill your oil filter completely and start your engine, pulling the fuel pump fuse would be a plus.
Old Nov 17, 2009 | 11:13 AM
lipadj46's Avatar
Great thanks mike. Hopefully I got the leak.
mike111
Jun 2, 2014 08:58 AM
oilspotLR
Feb 22, 2014 08:40 PM
oilspotLR
Oct 7, 2012 08:50 PM
wheelgarage
Oct 1, 2011 03:12 PM
logicmike44
Feb 22, 2011 11:01 AM
