at start up strained compressor noise for 90 seconds
Old Sep 8, 2007 | 03:05 PM
jonesprops's Avatar
8th Gear
Default at start up strained compressor noise for 90 seconds
Hi everyone, When i start my 2000 D2 it sounds like there is a little compressor strainin for about 90 seconds than stops.
this only happens the first time I start the car for the day.
Old Sep 8, 2007 | 04:44 PM
Default RE: at start up strained compressor noise for 90 seconds
Have you opened the hood and listened, might want to. Could be a bad belt, belt tensioner, idler pulley or if you have secondary, your air pump may be failing.
Old Sep 10, 2007 | 11:26 AM
jonesprops's Avatar
8th Gear
Thank you sir, will do. Will post results of further inspection.[sm=thanx.gif]
Old Sep 10, 2007 | 01:41 PM
S4poor's Avatar
Could be as simple as the hose popped off of the secondary air pump.
Old Sep 10, 2007 | 01:43 PM
jonesprops's Avatar
8th Gear
source of the noise is a motor attached to the firewall on the passenger side.
Old Sep 10, 2007 | 02:31 PM
OH Yes, the secondary air injection motor, unfortunately it is pretty normal, some get louder when some how they get water in the system.
Old Sep 10, 2007 | 03:23 PM
jonesprops's Avatar
8th Gear
Thanx for the info
you guys rock.
seaosrover
Feb 8, 2015 09:56 AM
schwaggy
Mar 21, 2011 08:57 PM
deucedaprodeuca
Feb 15, 2010 12:29 AM
andrewcloy
Sep 10, 2007 08:27 AM
