it started, but barely.
Old May 12, 2006 | 05:54 PM
opus13's Avatar
Default it started, but barely.
I went out for coffee this morning (okay, afternoon) and when getting back in to head home I had a hell of a time getting started. the engine turned over just fine and 'wanted' to catch but i had to sit and crank it for some time. It finally started and here I am at home, but i wanted to hit up a coupel trails this weekend and didnt want to leave myself stranded.
I've searched the forums (here and elsewhere) but havent come across someone else with this issue, only lots of mentions of the 'click of death'.
Nothing unusual, or impending disaster?
Old May 12, 2006 | 07:55 PM
Default RE: it started, but barely.
What year and model???????
Mike
Old May 12, 2006 | 08:12 PM
opus13's Avatar
95 DI, 3.9l
(thats weird, i could have sworn i put that into my signature)
Old May 12, 2006 | 09:04 PM
ORIGINAL: opus13
95 DI, 3.9l
You did and I didn't notice, sorry. I would look first at the fuel filter, then the fuel relay and lastly the pump. Common problem on the D1's. The fuel fiters are common at any auto parts store, try changing it out. The fuel pump relay as the pump ages starts cutting out, may need to be changed. The fuel pump also has a check valve that can stick allowing the stored fuel pressure in the rail to drop to zero causing the engine to just crank until the pump can get enough pressure back to the system.
There is a place to start.
Mike
Old May 13, 2006 | 05:07 AM
opus13's Avatar
thanks for the info. and dont worry, you arent blind -- i updated my signature after that post
caneraiser
Oct 31, 2012 06:15 PM
me 2
Audio/Visual Electronics
Jun 29, 2012 07:39 AM
chwelch
May 16, 2010 08:36 AM
ashc22
Apr 11, 2007 04:10 PM
