Starter Battery Cable
Old Jan 24, 2018 | 08:39 PM
AZRover's Avatar
Default Starter Battery Cable
Trying to order the cable that goes from the starter up toward the battery. Did a search on eBay using 'starter battery cable' and nothing comes up. Anyone know what the correct name for the part is?
Thank you,
Scott
Old Jan 26, 2018 | 05:18 AM
raid13's Avatar
unfortunately, that part is not sold separately though land rover's parts channel, only with an engine harness. used one striped off the engine harness or repair of original with new end unless someone has a aftermarket source...
Old Jan 26, 2018 | 09:35 AM
Davis31052's Avatar
I may be able to grab one for you at the salvage yard. I'm headed there tomorrow. One of the use parts guys down below may have one as well.
Old Jan 26, 2018 | 10:37 AM
number9's Avatar
May be available?
https://landrovermerriamparts.com/pa...iagram=7104250
Old Jan 26, 2018 | 01:08 PM
jamestfl's Avatar
Originally Posted by number9
dang- good find. May need to get one myself, mine is dry rotting / corroding from the inside out. Thanks.
Old Jan 26, 2018 | 07:03 PM
AZRover's Avatar
Davis thanks. See what you able to find out.
Scott
Old Jan 26, 2018 | 07:16 PM
shanechevelle's Avatar
Is that the factory cable? The illustration doesnt show the factory cable.
If youre going to just add a cable, go with a larger size than factory. It always seemed small to me.
Old Jan 27, 2018 | 05:25 PM
Davis31052's Avatar
Scott
I got your cable. PM sent to ya...
Gimebakmybulits
Jul 14, 2014 05:57 PM
johnkbl
Apr 23, 2012 07:49 PM
antichrist
Nov 2, 2011 02:55 PM
98roverguy
Aug 22, 2007 05:52 PM
FTB 2000 Disco
Dec 4, 2006 12:03 AM
