Starter Leads
Starter Leads
Hoping someone can help me with a wiring issue; hooking up a new engine in an ‘03 Disco 2 and can’t figure out where a couple of wires should go. Starter has two leads; large one that attaches via nut and stud, and smaller one with push-on connector. My large lead running to the battery had a smaller wire taped to it with electrical tape. When I unwrapped the tape, the small wire was damaged and didn’t have any kind of connector on it. Is this the lead that should have the push-on connector? And if yes, where does the wire run to?
I also have a wire with push-on connector that runs along with the wiring for the knock sensor on that side; is THAT the lead for the starter? And if so, what in the world is the damaged secondary wire for??
Thanks for any help.
Small damaged wire
Large lead
Closeup of small wire unwrapped
Small wire doesn’t seem to lead anywhere…
Small damaged wire
Large lead
