Starter Leads
Old May 6, 2022 | 09:27 PM
jrjr5000's Avatar
Default Starter Leads
Hoping someone can help me with a wiring issue; hooking up a new engine in an ‘03 Disco 2 and can’t figure out where a couple of wires should go. Starter has two leads; large one that attaches via nut and stud, and smaller one with push-on connector. My large lead running to the battery had a smaller wire taped to it with electrical tape. When I unwrapped the tape, the small wire was damaged and didn’t have any kind of connector on it. Is this the lead that should have the push-on connector? And if yes, where does the wire run to?
I also have a wire with push-on connector that runs along with the wiring for the knock sensor on that side; is THAT the lead for the starter? And if so, what in the world is the damaged secondary wire for??
Thanks for any help.
Small damaged wire
Large lead
Closeup of small wire unwrapped
Small wire doesn’t seem to lead anywhere…
Marco Kim
Aug 15, 2021 07:50 AM
86v8
Feb 19, 2018 06:15 AM
kip lightning
Jun 9, 2015 08:00 PM
Antinius
Apr 22, 2010 07:18 PM
frd1419
Jul 26, 2007 09:39 PM
