Starter solenoid: battery terminal spins
Old Sep 23, 2018 | 09:17 PM
Sandman614's Avatar
Default Starter solenoid: battery terminal spins
I am in the process of changing/upgrading my battery terminals and cables (amongst other projects). When I tried to remove the nut that holds the positive cable onto the starter solenoid the entire post spins... Did I damage anything inside? Are there new contact/plunger kits available, all I am finding are diesel starter kits..
4.0l Borsch V8
Old Sep 24, 2018 | 02:56 AM
JUKE179r's Avatar
If the whole post is turning then yes your battery is no good but can be used now as a door stop.
Old Sep 24, 2018 | 06:04 AM
Sandman614's Avatar
Postive terminal on the starter solenoid is spinning
Old Sep 24, 2018 | 07:21 AM
JUKE179r's Avatar
My bad... If I remember you can take apart the starter solenoid and check the terminal post from the inside.
On other solenoids I've added a slim nut to the post to keep it from spinning and so there is room to tighten down the positive battery terminal with the nut.
Old Sep 24, 2018 | 08:07 AM
Sandman614's Avatar
I can't do a lot with it until I can get the positive cable off of it. That's how it looks like they're supposed to come from this picture, unless they changed it later on.
Old Sep 27, 2018 | 05:51 PM
Sandman614's Avatar
So yes there is a possibility that the post can cause a no start. I can hear the solenoid engaging and releasing but it won't fire the starter. I'm assuming something inside got out of place and won't allow the solenoid to make contact. Just waiting on usps to being me my new solenoid..
04in719
Aug 2, 2017 12:16 PM
1998DiscoverySE
Jul 28, 2014 07:14 PM
edognight
Jul 18, 2013 12:58 AM
b c
Feb 14, 2013 11:16 AM
thehun
Nov 9, 2011 08:55 AM
