Starting Problems
Old Feb 9, 2020 | 01:03 PM
Holger Liedtke's Avatar
3rd Gear
Default Starting Problems
Hello since nearly 3 years i have massive starting problems with my disco. I start the engine i starts goes out and i have to start the bleeding procedure to get it starting again, when the car is running there is no problem while driving. I figured out that these starting problems occur most of the time the tank is half empty. I have changed nearly everything from the fuel pump, the fuel lines in the back, the fuel injector washer, the wiring loom, fuel pressure regulator and the filter housing. Does anybody have an idea? Many thanks (sorry if my english is not perfect)
Old Feb 9, 2020 | 05:51 PM
CollieRover's Avatar
Intermittent stalling issues are often the Crank Position Sensor. If you replace it, use only a Bosch unit. The other brands last a year or so.
RJ5
Sep 24, 2019 09:59 PM
disco-montana
Mar 12, 2011 12:32 AM
Law Dog
Jul 26, 2010 11:04 AM
reno-lr
Nov 18, 2009 08:12 PM
paul1454
Jan 16, 2009 09:19 AM
