Starts then stalls
This is starting to drive me crazy. As you may know, my Disco was stuck inn a river for 5 days.. It's obviously never run right since. It's starts then stalls. Here's what I've done so far.
Replaced airfirlter
Replaced all fluids (oil, trans, xfercase, diffs)
Replaced MAF (twice)
Replace main intake hose.
Replaced all spark plugs.
Wires are the 8mm and only a year old.
I get good spark at every plug so the coils are good.
Replaced the CPS.
Thinking maybe it had some water in the engine I drained the oil and filled the engine with Diesel fuel, let it run for 60 seconds, drained, flushed, and fill again with new oil.
I replaced just the Fuel Pump inside the tank.
The only part left I have to replace is the ECU unit. Tell me that's going to fix it!!!
Replaced airfirlter
Replaced the CPS.
I agree with Alex_M. If you indeed confirmed good spark, it's gotta be fuel related.
Do you have an ultragauge? If so, take a look at your O2 sensor output readings. I wonder if one or more sensors were possibly damaged. If you can keep it running long enough.
Other than that, is it just at idle that it dies? If you give it some throttle, will it run?
Also, do you have a SES light on? If so, what are the codes you're getting?
