Steering
Old Jul 6, 2020 | 11:02 PM
landroverdude's Avatar
Default Steering
Hey anyone know what's going on here? I just had new front and rear sway bar links installed and now my steering is very tight, I am perplexed as to why this is so, do they just need to be worn in maybe or what lol?
Old Jul 7, 2020 | 08:57 AM
XRAD's Avatar
should have no effect on steering. A new steering stabilizer will make steering more stiff...did they replace that too? Or change anything else?
Old Jul 7, 2020 | 09:09 AM
Nope it was installed by a land Rover specialist, they did not do anything else. Would this have required a ailment? Because on the paperwork they did not do that.
Old Jul 7, 2020 | 03:36 PM
Llamasayswhat's Avatar
what do you mean the steering is "tight"?
The wheel is heavier/hard to turn? The car sways or moves more with small steering inputs?
Old Jul 7, 2020 | 04:07 PM
For instance yes a tight feeling when it goes over certain parts, while I'm describing this I'm constantly turning the wheel left, so I start to turn the wheel left and it will be normal for a second then tight spot and ok again and then tight spot and the normal again and then tight spot, like that.
Old Jul 7, 2020 | 04:33 PM
SundayFunday's Avatar
I would have a look at the U-joint in your steering linkage located along side/just under the Driver side exhaust manifold.
it can dry out and cause the symptoms your describing.
I would spray liberally some wd40 which can be both a penetrant & a lube - or similar.
give that a try.
Old Jul 7, 2020 | 04:35 PM
boston4's Avatar
If I remember correctly, this is often a symptom of the steering shaft u-joints binding - not unlike what happens to the OEM front driveshaft where proximity to the hot engine cooks the grease inside. Not a serviceable part, needs to be replaced.
Not sure why sway bars would have any relation to this though - just something to consider.
mx468
May 31, 2024 08:18 AM
Boostle
Jan 23, 2024 05:09 PM
Kushan Gunawardane
Jun 19, 2020 08:00 PM
Cylenna
Oct 3, 2019 09:14 PM
Walko327
Feb 12, 2013 10:48 AM
