LR3 Steering
Old Oct 3, 2019 | 05:07 PM
Cylenna's Avatar
Default LR3 Steering
Steering problems. I have a lot of play in my steering. Just had it aligned and they said front end looked good but there’s a couple inches of play in the steering. Can’t drive it on the interstate. Have to be super cautious going around curves. New to these forums lol any advice would be great!
Old Oct 3, 2019 | 05:29 PM
houm_wa's Avatar
If it isn't the tie-rod ends (they said it looked good up front) then it's likely to be the steering column.
Old Oct 3, 2019 | 05:47 PM
DakotaTravler's Avatar
^ Ditto. Though they usually stiffen up a lot, not loosen up. The lower steering shaft is a known weak point and not terribly difficult to replace with basic tools.
https://landroverforums.com/forum/lr...g-shaft-88589/
Old Oct 3, 2019 | 09:14 PM
The one on my 07 is just loose and sloppy. No binding but the 06 would jam up. Lower steering shaft as stated is likely your issue
tommizerek
Aug 15, 2017 09:28 AM
tommizerek
Aug 8, 2017 02:57 PM
CollieRover
Jun 28, 2017 12:11 PM
Vinndego
Jan 6, 2014 11:14 AM
s10lowrider1994
Jan 7, 2013 09:41 PM
