steering box problem
Old Jan 29, 2009 | 12:22 PM
chrisusvi's Avatar
Default steering box problem
My 97 Disco 1 has alot of fluid leaking from the steering box. I don't know if the steering box needs to be replaced or if there is a leak at one of the hose connections. Is there a way to check to see where the leak is coming from so I don't have to spend $500 on a new steering box versus just replacing the hoses.
Thanks.
chrisusvi
Old Jan 29, 2009 | 12:41 PM
Default RE: steering box problem
Go power scrub off that earea of the gear box and see what is leaking.
Get back to us.
Old Jan 29, 2009 | 05:54 PM
What Mike said, degrease the steering box and engine, and make sure that you are adding Dexron III to the power steering system, geta quart with ATF stop leak in it and top off your P/S resevoir.
Very rarely will you need a new steering box.
johnkbl
Sep 21, 2023 06:17 AM
texci77
Jun 6, 2012 01:24 PM
DiscoBritney
Dec 19, 2011 06:24 PM
losinov
Mar 21, 2011 08:57 PM
ant996
Defender
Sep 14, 2006 05:03 AM
