Steering Box Replacement
Old Jan 20, 2021 | 02:06 PM
TimInNova's Avatar
Originally Posted by cvhyatt
Was hoping someone might have a youtube video or something a bit more visual.
It's a RHD Disco 1, but it's all I could find:
Old Jan 20, 2021 | 03:31 PM
TimInNova's Avatar
My steering box leaks as well and plan to replace it in the spring along with the upper and lower ball joints. I may go with a new one if I can swing it. The best price I've found so far is $1,000: https://www.suburbanautoparts.com/oe...RoCp88QAvD_BwE
If I can't I'll go with a re-manufactured unit, but need to further research the companies that sell the re-manufactured units.
Old Jan 21, 2021 | 10:03 AM
Harvlr's Avatar
If it was me I would try heat. Otherwise, I don't think a new track rod should be terribly expensive. If you get a new rod, make sure you put antiseize on the threads so this doesn't happen again.
Old Jan 21, 2021 | 12:21 PM
TimInNova's Avatar
https://www.handyhowie.co.uk/handyho..._Box_Swap.html
Old Jan 29, 2021 | 07:42 PM
cvhyatt's Avatar
Got a used steering box. Tackling this tomorrow. Wish me luck!
Old Jan 30, 2021 | 02:05 PM
cvhyatt's Avatar
Four hours in. Got the old box out. Cleaned up the replacement box. Waiting for the paint to dry and then I can stick it in.
Replacement box
Cleaning it up
Ready to prep for paint
Had to hit this with a 5lb to get it to break free
It was a beast but I got it out.
Cleaned, primed and painted with brake caliper paint. I know it will rust again but I can’t stand putting crappy looking parts back into the disco.
Took a bit of a break and swapped out the bulbs on the low beams with 100w Hella bulbs.
Probably more noticeable at night but the low beams are definitely whiter than the highs IMO.
Should of prepped the box yesterday so it would be ready to go in but it’s 70 and sunny so I should be able to get started again in an hour. Hopefully the install will be easier than the removal!
Old Jan 30, 2021 | 05:11 PM
cvhyatt's Avatar
Always something. Should have tapped these out before mounting.
Old Jan 30, 2021 | 05:58 PM
cvhyatt's Avatar
Default Dead 💀in the water
Followed the rave and dropped the intermediate shaft and universal joint. That was a mistake. Can seem to the universal joint back on the splines. What a cluster.
Any one have a suggestion ?
Old Jan 30, 2021 | 07:13 PM
cvhyatt's Avatar
Figured out I can stretch the opening of the coupling to the steering shaft so that may help me get it on easier. Got the Pangaea, drag link and steering box in. Going to retreat for now and deal with the intermediate shaft in the morning.
Also found time during breaks to install the dashboard repair kit. It’s a small success but I will take it.
Old Jan 31, 2021 | 06:14 PM
cvhyatt's Avatar
Originally Posted by ahab
I was not excited to try it myself, and as a result have driven with a slightly ****-eyed steering wheel for about 10k miles. I'm simply not undoing that steering box connection a 4th time. I used a 2' pipe wrench with my foot and could not get it to budge. Maybe if I get it up in the air and can get an extension on it.
I had major problems with this as well. My neighbor came by and offered to help. Brought some of this Tri Flow with him. This stuff is fantastic. I was able to to pull this shaft off and on multiple times with no sticking or friction.
Ben Matheson
Oct 24, 2024 09:29 AM
coors
Jan 31, 2016 03:36 PM
evansjoem
May 12, 2014 07:09 PM
texci77
Jun 6, 2012 01:24 PM
chrisusvi
Jan 29, 2009 05:54 PM
