Steering noise help
Old Mar 23, 2022 | 06:07 PM
Eutopia's Avatar
Default Steering noise help
Hi, I have a pretty strong high pitch noise when turning , also the steering fluid is leaking . I took the Steering pump off and it looks like its leaking from the hose under the SP . I know sometimes it leaks from the steering gear box also , so I can't really tell where is it leaking coming from . Can the noise come from the steering gear box also? I only paid 1K for the car , so I can't spend the money for new or reman gear box and SP . Can someone tell me what rebuild kit do I need for the SP and gear box ? Should I rebuild them ? Is it hard? Any help would be nice , thanks a lot !
Old Mar 24, 2022 | 06:51 AM
The_OGCJR's Avatar
You only spent 1k on it and you can’t afford to fix anything? Or you dont want to put money in it?
how do you know it’s not the ps pump?
You can rebuild the pump and the box.
I bought a reman pump and put in Lucas stop leak. It eventually stopped leaking lol.
Old Mar 24, 2022 | 07:46 AM
Eutopia's Avatar
I don't really know if is the pump , but I thought sense I have everything out , to rebuild both the SP and gear box , just in case....I was wondering if the gear box can make the noise like SP .... Thanks
lestro
Jun 21, 2021 05:13 AM
OffroadFrance
Mar 6, 2017 09:14 AM
DiscoGrlNC
Oct 27, 2011 10:50 AM
DiscoGrlNC
Oct 24, 2011 03:42 PM
chrisusvi
Jan 29, 2009 05:54 PM
