Is it the steering pump or box!
Old Dec 6, 2009 | 12:28 AM
caleb's Avatar
Default Is it the steering pump or box!
PLease help i am getting discouraged with this whole steering issue. I figured fluid leaking from the steering pump gasket meant the gasket has failed and is causing major air into the system. So i changed the gasket and installed the pump also changing the inlet hose. I can't seem to get power steering back. i am turning the wheel lock to lock with the car on and bleeding the steering box but the wheel is still hard to turn. LR Seattle tells me it is the Pump even though i changed the gasket. How many of you believe (1) the problem is with the internal working of the pump unable to get up to pressure. Or (2) the problem is the box, . without the proper pressure gauges is just can't be sure. Any help would be apppreciated....
Old Dec 6, 2009 | 06:43 AM
lipadj46's Avatar
It should be easy to see if you have pressure. Open up the bleed valve and crank the wheel. If PAS fluid shoots up and hits your hood then you have pressure.
Old Dec 8, 2009 | 07:49 AM
d1bob's Avatar
I just replaced steering gear box.......make SURE, steering wheel does NOT MOVE while all undone, otherwise you will be replacing spool assy in steering column under steering wheel.....fyi
Old Dec 8, 2009 | 10:50 AM
xengineguy's Avatar
Is the fluid in the tank foamy?? If it is your sucking air from somewhere. What did you use for a gasket in the pump? If it was home made paper type, (that may be the problem) I have good luck only with gray "stiff or rigid" RTV permatex brand. It fills the gap without changing the inside clearances of the pump.
johnkbl
Sep 21, 2023 06:17 AM
Joseph M. Broomhead
Feb 4, 2013 03:14 PM
bennycisco
Jan 21, 2013 07:40 AM
Boxkid1
May 3, 2012 05:47 AM
losinov
Mar 21, 2011 08:57 PM
