Steering "sticks" - PS fluid bubbling
Old Feb 3, 2015 | 11:49 AM
cbrf23's Avatar
Default Steering "sticks" - PS fluid bubbling
So I've had my disco for a month or so - bought it with a blown head gasket and fixed that, been driving it since - put a little over a 1,000 miles on it and it's developed a few new problems in that time.
The one that I'm a little confused on is this steering issue. This just started a few days ago, it was driving just fine before that (no issue at all). Now, when I start the car after it's been sitting for a while, there is barely any PS assist. It seems to "stick" in certain locations as a turn the wheel, i.e. when wheels are straight and I start to turn steering wheel, there is no power assist, then after about 20 degrees rotation I get assist for about 20 degrees, then back to no assist.
As I drive the car it gets better - still a little notchy but less noticeable. If it drive it for a while (like 20 minutes plus) it seems to go away entirely.
I noticed when the vehicle is running the power steering fluid in the reservoir is bubbling pretty heavily. Not like little bubbles, but like a rolling bubble (as if boiling water). I believe this is air as it is like this from the second it starts and stays steady as I drive it. Is this norma??
This is real annoying, and I my first thought was like a u-joint on input shaft or steering knuckle could be binding or something, but like I said this started pretty suddenly and the fact that it gets better as I drive it makes me think it's not a mechanical wear issue like that but something hydraulic maybe.
Old Feb 3, 2015 | 12:01 PM
dusty1's Avatar
bubbling/gurgling is normal. air in the system is not. I would first try to bleed the box. if you have a leak, you could be letting air in.
parke
Jun 21, 2014 03:52 PM
coors
Jan 25, 2011 07:50 AM
robsDisco
Apr 15, 2009 09:35 PM
mackshawnd
Feb 28, 2009 05:44 PM
dickensheets
Nov 6, 2006 12:32 AM
