Still Cant get it out of park
Old Apr 3, 2010 | 06:07 PM
  #21
Danny Lee 97 Disco's Avatar
Afterthought, someone should disassemble a failed one and perform "Root Cause Analysis" And it is only a simple switch, but 20 or 80 is ridiculous, especially if it is from certain areas of the world.............
Old Apr 3, 2010 | 10:24 PM
  #22
Robmcin's Avatar
Originally Posted by TheBlackBastard
I had the same problem today...I came out of the grocery store and the Disco won't shift out of park. It's a 2000 Discovery II. The "click" when stepping on the brake is not there. I didn't check to see if the brake lights worked. A friend gave me and the groceries a ride home, but the Disco is still in the store p-lot. I've read through this post... my one question is: Where is the brake switch? What tools will I need to remove/replace/inspect it? My manual is still in the car... Thanks for any help!
Once you get the switch the only tool you really need is your hands.. it just twists 90 degrees and comes out, new one in, twist 90 back
and done
Old Apr 8, 2010 | 06:54 PM
  #23
duncanskyler's Avatar
Alright guys got the new switch had it tested at Napa and it works. Get it in the car. the differential lock light still comes on and beeps everytime I step on the switch. I found the little button inside the gear shift to get it out of drive, but dam, there has to be something I'm missin, I still have no brake lights and there is still no click when I step on it. Does anyone have the fuse list for 01 Disco SD II
beyeker
Aug 11, 2015 05:47 AM
TRIARII
Dec 17, 2012 07:51 AM
elboy0712
Dec 9, 2011 11:17 AM
HaasDisco
Aug 27, 2006 05:49 AM
mge_1
Jul 21, 2006 01:54 AM
