Still got the 3 Amigos
Old Nov 11, 2015 | 04:25 PM
bostongrun's Avatar
Default Still got the 3 Amigos
I have an 02 Disco with 150k, I was getting intermittent 3 Amigos. I don't have a Hawkeye Scan Tool so I took a risk and installed a Shuttle Valve because many sources said the Shuttle Valve is the cause 98% of the time. It was great for a week but today they came back.
Another person on this forum said I should remove the shuttle valve again, which can apparently be done without disconnecting the six lines, avoiding the chance of a stripping out the soft and aluminum thread in the module and the need to bleed the brakes. After I remove the shuttle valve, I should remove the internal connector jack and reroute the two brown wires to the outside extend the wires run one to a ground and the other to the green and yellow wire that is part of the large multi-wire jack on the right side of the module.
All I did before was change the shuttle valve but apparently it wasn't enough.
I am on the right track now?
Old Nov 11, 2015 | 04:59 PM
matt3502's Avatar
https://landroverforums.com/forum/di...s-fault-26847/
Follow this for the bypass.
Old Nov 11, 2015 | 05:06 PM
coors's Avatar
Have you reset the ABS module after making the initial repair? If not, I highly suggest it.
Yes, this.
"Remove the shuttle valve, I should remove the internal connector jack and reroute the two brown wires to the outside extend the wires run one to a ground and the other to the green and yellow wire that is part of the large multi-wire jack on the right side of the module".
Old Nov 12, 2015 | 11:21 AM
stuckntx's Avatar
You have to reset the abs. I have an icarsoft930, reset and they came back after 100 miles. Pulled the shuttle valve and they both tested fine. So option b for me. It took about an hour and I have not had 3 amigos. It has been one week. If you own a disco 2, a code reader is a must!
Charlie_V
Aug 27, 2015 04:37 PM
BrandonS
Jun 25, 2012 02:27 PM
glassman66
Apr 19, 2012 10:17 AM
cipher982
Dec 14, 2011 06:01 PM
lipadj46
Sep 12, 2009 07:31 AM
