Still overheating
Old Oct 30, 2021 | 10:09 AM
Maxwell_land's Avatar
Default Still overheating
I have gotten a chemical test and a pressure test changed out the thermostat and checked the water pump but still I am over heating any other suggestion
Old Oct 30, 2021 | 12:18 PM
Externet's Avatar
What is overheating for you ? What coolant temperature are you running ? What is your ambient temperature ?
If were you, I would eliminate completely the thermostat and its bypass hoses to diagnose, then re-measure coolant temperature.
Old Oct 30, 2021 | 12:32 PM
I ordered a temp gun the gauge has quit working altogether but it's getting really hot and the under hose of the thermostat is cold
Old Oct 30, 2021 | 01:44 PM
Richard Gallant's Avatar
@Maxwell_land this not rocket science, it is the same as every other vehicle:
  • Rad
  • water pump,
  • thermostat
But you can do nothing without knowing the temps, start simple :
  • Get a eml327 bluetooth OBD from amazon a25-50 will do - if you have an Iphone make sure it is compatible
  • Get torque for your phone
  • Set it up
  • Start your truck and let it get to full operating temp 188-212 depending on thermostat for about 10 minutes
  • give it a few revs
  • shutdown
  • Check hoses
Now you can diagnose
Old Oct 30, 2021 | 06:03 PM
Extinct's Avatar
Get an inline thermostat. Remove the thermostat element completely. Loosen the radiator cap one full turn from full tight. If it still overheats you have a plugged radiator. Even a truck with a blown headgasket will not overheat if there is coolant in it and no thermostat in the housing.
Brandon318
Jun 8, 2019 05:41 AM
seminolef1
Nov 26, 2012 11:18 AM
boilerman
Nov 12, 2008 07:35 AM
