Still stuck in PARK, new brake switch, lights work.
Old Apr 30, 2014 | 05:03 PM
ImQuattro's Avatar
Default Still stuck in PARK, new brake switch, lights work.
The pin that locks the selector is not releasing (or even trying).
Any other common problems that cause this beyond the brake switch?
Old Apr 30, 2014 | 05:33 PM
Jared9220's Avatar
Didn't you have a problem getting your key out? (It may have been a different person) If so then you may have damaged the ignition switch.
Old Apr 30, 2014 | 05:59 PM
ImQuattro's Avatar
Yes, that was I, but the theory is doubtful. Ignition works properly.
Old Apr 30, 2014 | 06:41 PM
Jared9220's Avatar
1)Does the gear indicator on the Dash also say "P"
2)Does the truck start?
3)Are you still having trouble getting the t-case to go into Hi?
4) have you done any repairs recently?
Old Apr 30, 2014 | 07:41 PM
ImQuattro's Avatar
Yes, the dash say's P
Yes it starts
T-case is in H now, it was stiff from apparently never being used (bought from original owner 93Kmile of suburban use).
Um, yeah, lots. Complete engine rebuild, drive shaft rebuild(s).
Old Apr 30, 2014 | 09:48 PM
Jared9220's Avatar
Let's move this back over to your old thread since it has more history about this problem.
amer_qureshi
Jul 10, 2024 02:03 PM
ImQuattro
May 1, 2014 08:36 PM
weepit
Aug 6, 2012 04:52 PM
mattrickman
Jan 17, 2011 10:07 AM
