Still working on misfire
Old Dec 2, 2012 | 10:18 AM
Akumal's Avatar
Default Still working on misfire
Have trouble finding problem. Codes 1300, 300, 301, 305, 306, 308.
New bosch sensor, new bosch plugs, new STI wires. Runs way to rich. Plugs are not burning gas, checked plugs with misfire, they are wet with gas. Gray smoke out the exhuast, has strong gas smell. Decided to have injectors cleaned, no change. Checked fuel pressure. Key in position 2 (car not running ) no pressure. Start car 50 psi, turn key off no pressure. Not sure what to check next, thinking of changing plugs or at the very least swap them around and see if i can move the misfire. Not sure why pressure drops as soon as key is turned off. Any thoughts, thanks
Old Dec 2, 2012 | 10:23 AM
lr2001silver's Avatar
Banned
Coil pack would be your way to see if misfire follows.
Old Dec 2, 2012 | 10:29 AM
Akumal's Avatar
I'm having misfire on both coil packs, thats why i was re-thinking plugs, thanks
Old Dec 2, 2012 | 06:21 PM
mirrajumper's Avatar
My coil packs went bad 2 weeks ago instantly. Working fine one day and not the next. Plugs and wires by themselves did not fix the problem. New coils and truck was driving properly. You can mess around with a bunch of stuff and drive yourself crazy or just install new ones!!
Old Dec 4, 2012 | 03:08 PM
Akumal's Avatar
Removed coil packs from car, tested with multimeter. secondary cheched out fine, all around 13.99K Ohms. Primary was not in spec. All 4 checks showed over 1.5 to 1.7 Ohms. Should have been no more then .055 Ohms
I guess i need to new coil packs
Old Dec 4, 2012 | 03:38 PM
Banned
Sounds like you do.
Old Dec 6, 2012 | 06:34 AM
Akumal's Avatar
I miss read my meter, coils check to be good. Swapped them to see if it would make a difference, no change. Still have same codes.
301,305,306,308,1300,300. No more fault codes, no sensors, nothing.
I will make a compression test as soon as i can put my hands on a tester, not sure what to check after that. Need help, thanks.
Old Dec 6, 2012 | 06:46 AM
drowssap's Avatar
you say you still have the same codes, did you clear them and they returned?
Old Dec 6, 2012 | 07:11 AM
Akumal's Avatar
Yes the codes cleared after every test that i make, always comes back with same codes.
Old Dec 9, 2012 | 12:51 PM
Akumal's Avatar
Can a defective crankshaft sensor cause this problem. Do not have a fault code on sensor but have been told that it will not always throw out code.
just asking
tsuyoi
Sep 22, 2020 10:37 AM
texci77
Jun 1, 2014 04:07 PM
pdowning6
Apr 30, 2012 08:38 AM
me 2
Apr 11, 2012 08:56 AM
00rove
Mar 6, 2012 07:10 AM
