Is this a stock driveshaft
You can't tell by the end pictured. You need to look at the other end with the double cardon joint. If those two u-joints have grease fittings then it's been done, if not it should be replaced or rebuilt. You may want to do it anyway, unless you absolutely know for sure it was done recently which I'm guessing you don't know by the sound of the question.
It's well worth the money to rebuild or replace it, much better than having to buy a new one, along with a transmission when it finally does go BANG!
robert.juric
Nov 3, 2022 06:08 PM
LandRoverChic
Nov 11, 2014 04:54 AM
DiscoSux
Nov 17, 2010 09:46 PM
