stops running won't restart
Old Jun 17, 2017 | 06:25 PM
senordan's Avatar
Default stops running won't restart
My 03 discovery would just kick over but wouldn't fire and run. found out no signal from crank sensor to computer. replaced sensor and worked fine for 600 miles. Now 4 or 5 times stop at signal or gas station and engine dies but can restart after about 5 minutes.
any ideas?
Old Jun 17, 2017 | 07:26 PM
Mskembo's Avatar
Clean your Mass Air Flow Sensor and then your Idle Air Valve. It's not fool proof, but it's a pretty common failure point. Make sure you use MAF cleaner on the MAF Sensor or you will definitely be replacing it.
Old Jun 17, 2017 | 08:48 PM
Alex_M's Avatar
Sounds like a crank sensor to me. Next time it happens pour a couple bottles of water over the sensor and try again. That will cool it off. If it starts then there's your problem.
Old Jun 17, 2017 | 08:52 PM
Mskembo's Avatar
My CPS just made it so it wouldn't start for a while, it never died on me. Still a very good thing to check.
Old Jun 18, 2017 | 02:12 PM
Alex_M's Avatar
They can go both ways. When mine went it quit driving down the road.
dschloe
Aug 21, 2008 10:27 AM
Rover5150
Feb 11, 2008 12:52 PM
Tallguy
Jun 5, 2007 10:35 AM
Tallguy
Jun 4, 2007 02:59 PM
trailhead4x4
May 25, 2005 08:48 PM
