Problems Starting After HG/TimingChain Job
Old Jun 18, 2017 | 03:12 PM
robert.juric's Avatar
Default Problems Starting After HG/TimingChain Job
So while I've been battling a misfire after my HG job, I've also come upon the problem of not wanting to start. It sounds like its trying to turn-over but won't catch. Some of the times I just let it set and come back to it in the afternoon and it will start up.
Someone mentioned the CPS. I recently replaced it less than a year ago, and unless some cleaning/degreaser ruined a new sensor I don't know if that is the issue or not? Could the failed starts be related to the misfires I've been experiencing (timing chain/oil pump?) or is the CPS still a strong possibility?
Old Jun 18, 2017 | 05:19 PM
Yep, sure enough. 4 hours later on my way out the door I decide to give it one more go and it starts right up.
Old Jun 18, 2017 | 08:52 PM
disc oh no's Avatar
One thing that can cause this is a bad coolant temp sensor. I would check that to make sure the engine temp is correct. If it's reading too low of a temp, the computer will flood the engine with fuel.
mpothen
Mar 23, 2016 08:42 AM
nhigdon11
Dec 19, 2012 08:38 PM
lyleorszulak807
Oct 17, 2010 11:07 PM
paul1454
Mar 6, 2009 05:16 PM
DetroitRover
Sep 12, 2008 12:12 PM
