Stranded (ONCE AGAIN) by my DII.
Old Dec 19, 2008 | 10:05 PM
ryanD2's Avatar
Default RE: Stranded (ONCE AGAIN) by my DII.
well im in pa but im heahed home to frederickburg in the morning, id be more than happy to try and give you a hand or pool ideas and try to get it fired up in the morning.
Old Dec 19, 2008 | 11:33 PM
phatduc's Avatar
ORIGINAL: Spike555
Sounds like the fuel pump.
Easy test that worked great in my VW with bosch injection to isolate a dead fuel pump: grab a cup and straw from the friend micky Ds, and fill it with some gas. Use the straw holding your finger over the top opening to release a thimble full of gas into five or six cylinders through the spark plug hole. then crank it over. if its the fuel pump it should fire right up for about 3-5 secs, then die as the gas is used up.
good luck mate!
________
Jailbroken
Old Dec 20, 2008 | 05:30 AM
rinmud's Avatar
if the check engine light doesnt extiquish after 6 seconds cranking yes fuel pump, its not like the good old days when they screamed for months before taking a dump. one last thing look at the fuel pump relay and pull it out, see if theres been a barbaque in there lately. scott
Old Dec 20, 2008 | 09:48 AM
I just e-mailed you, get back to me.
Old Dec 20, 2008 | 08:45 PM
2000 DII's Avatar
Update:
Well, made the hour drive back to my truck this morning. Still wouldn't start. I was gettingspark at the plugs though. I checked the fuel pump fuse and it was in great shape with no barbeques.I didn't remember to try the idea of putting as little gas in some of the cylinders. Decided to check with the Goodyear joint 60 yards from where my truckwas. They said if it's a fuel pump they can fix it. $103.00/hr labor charges. Oh boy!They also said they can just rollit straight down the parking lot right into their bays. That should be interesting. Dang, I forgot to tell themit's a heavy truck. I'm sure they'llnail me for an hours labor for rolling down the hill. I'm afraid this one's gonna hurt a bit.
RyanD2...thanks for your offer!I really appreciate that buddy.
Old Dec 20, 2008 | 09:01 PM
phatduc's Avatar
$100+ an hour is about right, for someone who knows exactly what they are doing... The fuel pump requires a tank drop too. I justimaged the rave CD for the D2 if you wantit emailed to you in PDF. It's unreal. Atleast you can tell the goodyear guys what to do next. its 650megs about 4 hrs to dump on a broadband connection.... good luck with it man!
________
Vehicle insurance forum
pwaltrip
Nov 28, 2012 09:27 AM
Freelanderfree
Freelander
Mar 28, 2008 11:04 AM
ceven18
Mar 22, 2008 10:50 AM
ceven18
Mar 18, 2008 09:36 AM
