Stripped Rear Brake Line Nut - Repair/Replace Options?
I had a frozen caliper, stainless steel brake lines and a rental Nanocom. So I thought this would be a perfect time to replace the front calipers, replace the brake lines and bleed the brakes. Made it through three without a hitch but stripped the passenger rear. Is there an easy way I can replace this fitting?
New caliper and brake line installed
Caliper and brake line installed Stripped fastener.
yes, but you will need a double flare/compression crimp tool and new nut. I have one of these and love it (pretty much for the bench and not in the car, but you get the idea..):
There are cheaper and simpler versions.... maybe rent one? You need to know the flare angle but pretty easy to match. You can cut the tube shorter and add a short length, or maybe there is enough tube to work with....or replace the whole tube....
Thanks @XRAD I saw that I could probably rent one. I would prefer reusing the line as is if I can get away with it. What type/size fitting do I need? (Edit) - I'm thinking this will work and I can just rent the flare tool?
just cut the nut off (raise up nut if possible and use a tube cutter) , and bring nut, tube, and an old brake line to match at the store. There are only a few common fittings so this one should not be too hard to match....
