Stripped Rear Brake Line Nut - Repair/Replace Options?
Old Jan 19, 2020 | 04:37 PM
cvhyatt's Avatar
Default Stripped Rear Brake Line Nut - Repair/Replace Options?
I had a frozen caliper, stainless steel brake lines and a rental Nanocom. So I thought this would be a perfect time to replace the front calipers, replace the brake lines and bleed the brakes. Made it through three without a hitch but stripped the passenger rear. Is there an easy way I can replace this fitting?
New caliper and brake line installed
Caliper and brake line installed
Stripped fastener.
Old Jan 19, 2020 | 05:11 PM
XRAD's Avatar
yes, but you will need a double flare/compression crimp tool and new nut. I have one of these and love it (pretty much for the bench and not in the car, but you get the idea..):
https://www.eastwood.com/professiona...yABEgL-BPD_BwE
There are cheaper and simpler versions.... maybe rent one? You need to know the flare angle but pretty easy to match. You can cut the tube shorter and add a short length, or maybe there is enough tube to work with....or replace the whole tube....
and then you need the right nut....
Old Jan 19, 2020 | 05:15 PM
cvhyatt's Avatar
Thanks @XRAD I saw that I could probably rent one. I would prefer reusing the line as is if I can get away with it. What type/size fitting do I need? (Edit) - I'm thinking this will work and I can just rent the flare tool?
https://www.autozone.com/brakes-and-...60_90074_92959
Old Jan 19, 2020 | 05:34 PM
XRAD's Avatar
Don't know the size off hand....
just cut the nut off (raise up nut if possible and use a tube cutter) , and bring nut, tube, and an old brake line to match at the store. There are only a few common fittings so this one should not be too hard to match....
Old Jan 19, 2020 | 06:01 PM
zuke's Avatar
In the meantime, pick up a set of flare nut line wrenches. They are kind of a must for working on brakes. Were you using vice grips.
Old Jan 19, 2020 | 06:05 PM
cvhyatt's Avatar
Yeah I have the flare nut wrenches. Unfortunately that's what rounded the nut to begin with so I had to switch to vice grips to get it off.
Old Jan 20, 2020 | 07:24 PM
cvhyatt's Avatar
Got this repaired. Need to bleed the brakes one more time. Thanks for all the advice!
Using the flaring tool
Finished product. It’s ugly but no leaks.
Old Jan 22, 2020 | 12:20 PM
PalmettoDisco's Avatar
By chance, do you recall the flare angle? For future reference.
Old Jan 22, 2020 | 12:51 PM
cvhyatt's Avatar
Flare angle? Seemed like it was completely horizontal but I don’t think I got it back exactly the way I found it but no leaks so far!
jimvw57
Oct 8, 2017 02:08 PM
97GreenMeanie
Oct 6, 2015 10:28 AM
Hawkeye712
Aug 31, 2015 03:44 PM
calebbo
Aug 22, 2011 07:37 PM
geek_IM
Sep 23, 2010 08:26 PM
