Strong Vibration while turning of the engine on d2 2004
Old Oct 10, 2021 | 11:16 AM
daniel tamar's Avatar
Default Strong Vibration while turning of the engine on d2 2004
Hi, just bought my first landrover
Any suggestions what could be the problem?
Old Oct 10, 2021 | 11:47 AM
Harvlr's Avatar
Hi Daniel. You should give more information. Is it vibrating because it’s misfiring, or is there an actual imbalance in the engine? Did it run smoothly and suddenly vibrate, etc?
Old Oct 10, 2021 | 12:38 PM
Hi harvir, the engine is working smoothly , the strong vibration happens just at the moment I switch off the engine only for 1 second.
thank you
Old Oct 10, 2021 | 02:08 PM
Harvlr's Avatar
My guess is that it’s nothing to worry about, but maybe someone with more knowledge will chime in.
Old Oct 10, 2021 | 02:12 PM
Harvlr's Avatar
Is it “dieseling”? (Trying to continue running). That used to be quite common on carbureted engines but electronic fuel injection usually runs so clean this never happens. Also EFI cuts off the fuel when you turn off the key, so I just talked myself out of that theory.
Old Oct 10, 2021 | 04:50 PM
whowa004's Avatar
motor mounts shot?
Old Oct 11, 2021 | 11:57 AM
Best4x4's Avatar
Motor mounts, fan blade, or maybe the harmonic balancer.
NewToTheTwo
Oct 12, 2019 07:57 PM
PAPAGALLO
Jan 23, 2017 06:23 AM
jbarr89
Jun 21, 2016 12:43 PM
lagebrooks
Jul 20, 2006 11:53 AM
LiftedRover96
Feb 7, 2006 10:41 PM
